Can't edit tags
  • spldep6356
    • Feb 2009
    Can't edit tags
    When I try to edit an ID tag nothing changes.
    I have an MP3 with a blank tag. I right click on the file. Insert a name of the artist and then click ok. Nothing changes. When I go to edit the tag again it is still blank.
    I am using Win10
    Re: Can't edit tags
    Which software are you using to edit the blank tag? Perhaps post a screenshot?
    • spldep6356
      • Feb 2009
      Re: Can't edit tags
      I think it is version 13.5
        Re: Can't edit tags
        The question was which software are you using, not which version.
        I assume dBpoweramp is the software and you are using the Edit ID-Tag context menu option?
          Re: Can't edit tags
          Email the mp3 file please:
          Other mp3 files you are able to tag?
          • spldep6356
            • Feb 2009
            Re: Can't edit tags
            No. still having the problem. It is every MP3 file.
              Re: Can't edit tags
              Please can you describe exactly how you are trying to edit your mp3 files? Did you send Spoon an mp3 file?
