Cloud Storage (help?)
  • monsterjazzlick
    • 1764
    Hi folks,
    I have now finally finished ripping my Jazz library to FLAC. This has taken 4 x months and amounts to nearly 100GB.
    I was looking at various online cloud-storage packages over the weekend as I was thinking of maybe uploading all of my rips for safe keeping. Some companies offer very cheap deals while other are more expensive (I am not sure why the price differences - for basically the same thing - are vastly different?).
    Amazon (whom I have 'Prime' with) charge 55GBP per annum for UNLIMITED GB. But I would only need circa 150GB and so I think 55GBP per annum would be expensive for my needs:
    I looked at Google Drive which offers 100GB @ 1.59GBP per month. Their next level up is 1TB which costs 7.99GBP per month:
    Any help would be appreciated.
    Many thanks,
    Paul
    • 6185
    Re: Cloud Storage (help?)
    I cannot speak for any of these as I do not use them. But be careful. Some cloud audio file storage options will replace your files with lossy mp3 files from their own library. You do not want this. You want storage for your EXACT files. So read the fine print.
    • monsterjazzlick
      • 1764
      Hi Gary,
      Yes, Amazon do exactly that with one of their packages. I managed to pin-point the representative down and get a straight answer in the end out of her. Even then she said that Amazon's mp3 versions are far higher quality than anything else on the market. I could not even be bothered to argue!
      Paul
      • evasv
        • Jan 2016
        • 114
        The only long-term solution you can trust is your own. There's little guarantees with online services. How do they protect the integrity of your files? Will they continue their service next year? Will they even be in business in a few years?
        Unless you need access to your backup on the go, I think it's better to buy more (external) hard disks for the money instead (at least two backup disks, one preferably away from home).
        But if you already have a hard disk backup of your collection, online backup can be an additional alternative. Just don't trust it as your only backup.
        Personally, I think it's easier and safer to stick with multiple hard disk backups.
        • Jailhouse
          • Sep 2016
          • 388
          You could try storing your FLACs in zip files and sending those to the cloud. If the vendor doesn't open the zips--which they shouldn't--you're good.
          • monsterjazzlick
            • 1764
            Hi evasv,
            I did not really expect Cloud Storage companies to be fly by night, or for this type of service to be superseded in the immediate future, because I envisage it to be here for the long term. But I guess nothing is for certain.
            I have, and use, the FREE Google Drive service (albeit it is 15GB and I have already filled it with random junk etc).
            My FLACs are currently stored on the 'C' Drive of my home PC, a 200GB SanDisk micro-SD card, and a Dell 1TB (USB powered) external hard-drive.
            Paul
            • monsterjazzlick
              • 1764
              Hi JH,
              Would you store EVERYTHING in 1 x zip? Or, say, each ALBUM ARTIST in 1 x zip?
              Paul
                • 6185
                Hi JH,
                Paul
                Everything in one zip. The zip file can maintain the underlying folder structure.
                • monsterjazzlick
                  • 1764
                  OK, cheers Gary. I think I am about 2/3 through ripping my library now. Paul
                  • evasv
                    • Jan 2016
                    • 114
                    OK, so the cloud storage would be an additional backup.
                    You could perhaps password protect the zip file to increase integrity? I don't know how vendors store the files, if they repackage even zip files, but the Amazon example was frightening.
                    • monsterjazzlick
                      • 1764
                      Evasv,
                      Yes, I was shocked about Amazon.
                      I might just be safer investing (as you say) in an extra HD, filling it, then storing at my parents house.
                      Paul
                      • evasv
                        • Jan 2016
                        • 114
                        You have "decent" safety since you have the internal hdd + SD card + external hdd at home, but it certainly wouldn't hurt to have an additional remote backup. Cloud storage is probably safe if you can confirm that you get the same zip file back, but you'd have to monitor they stay in business and check your files now and then. A remote hard disk is a bit safer in my opinion, but has to be checked upon and could fail.
                        Myself, I have my collection on 3 external hdd's - 1 that I rip to, 1 that I play from and 1 at a friend's house. I probably should have a 4th one considering the amount of work that goes into my collection. How many backups is considered safe & sane?
                        • monsterjazzlick
                          • 1764
                          Hi Evasv,
                          I would say that 3 storage devices is the norm - esp. if you keep one at a different location. But 4 devices would be much better; and I think adequate.
                          Of course, the HD which is located outside of your home would need to be regularly topped up with your most recent rips to keep it up-to-date.
                          Paul
                          • evasv
                            • Jan 2016
                            • 114
                            Yes, and that was problematic during the years when I ripped a lot of CDs. Nowadays my ripping is sparse so I only top up once a year.
                            • monsterjazzlick
                              • 1764
                              It will be another four months at least until I am at that stage!
