TuneFUSION
  • DigitalLA
    • Sep 2007
    • 71
    TuneFUSION
    If I have ripped many CDs to a single computer and have manually copied tracks to a networked computer, will TuneFUSION tell me if I have forgotten to copy certain tracks or albums? And will it know when I have copied an album but given its folder a name that differs from the name of the folder on the source computer, for example "The Temptstions" vs. "Temptations"? Thanks.
    • 46186
    Re: TuneFUSION
    You would remove all the files from your network computer, then let tunefusion sync all the files, leave tunefusion running and you never have to worry about syncing again, it is fully automatic.
    • DigitalLA
      • Sep 2007
      • 71
      Re: TuneFUSION
      I am afraid of using a syncing feature that will delete files. I may have some unique files on computer A and some unique files on computer B. Will TuneFUSION have an option not to delete files and to show the user which files are unique to each computer? Thanks.
        • 46186
        Re: TuneFUSION
        TuneFusion never deletes any of the source files.
        • DigitalLA
          • Sep 2007
          • 71
          Re: TuneFUSION
          But will it delete files from the destination in the sync process? What if a song has a few bits that differentiate the same song from the source version?
            Re: TuneFUSION
            If you want to keep different versions in separate locations, then I guess you don't want TuneFUSION, as it is a syncing app.
            • DigitalLA
              • Sep 2007
              • 71
              Re: TuneFUSION
              Could I restrict the syncing to one folder within the destination drive? For example, if the destination drive has a capacity of 12 TB, may I create on it Folder A and Folder B and have Tunefusion sync to only Folder A and not delete any of the contents of Folder B? In this scenario, Tunefusion syncs from the source drive to Folder A but lets me store whatever I want in Fokder B, which might contain different rips of many of the same songs that reside on the source drive and in Folder A.
                • 46186
                Re: TuneFUSION
                Yes, you can set to sync to a network folder location.
                • DigitalLA
                  • Sep 2007
                  • 71
                  Re: TuneFUSION
                  Great. My source computer is at the moment inaccessible except that I may still be able to copy files to and from it. Is it possible to run Tunefusion from the destination computer (a Mac running Windows 10 as a virtual machine in Parallels)?
                    • 46186
                    Re: TuneFUSION
                    Yes you can.
                    • DigitalLA
                      • Sep 2007
                      • 71
                      Re: TuneFUSION
                      The destination iMac houses Tunefusion in a Windows 10 VM, but Tunefusion can&*8217;t see the networked HP Windows Vista machine, though the iMac can see the Vista machine in MacOS. How Can I get Tunefusion to see the networked source PC? Thanks for your help.
                        • 46186
                        Re: TuneFUSION
                        Map the networked PC to a drive letter (you can right click on the share >> map to network drive), click the option to reconnect the share at log in.
                        • DigitalLA
                          • Sep 2007
                          • 71
                          Re: TuneFUSION
                          I think the Windows VM can&*8217;t see the networked drive, though MacOS can. How would I get the Windows 10 VM to see the networked PC and NAS? Thanks again for your help.
                            • 46186
                            Re: TuneFUSION
                            It would need access to your local network. This question would be better posted on the forum of which ever VM host you are using.
                            • Frank.Kassel
                              • Sep 2018
                              Re: TuneFUSION
                              hello together
                              i'm using dBpoweramp Music Converter, PerfectTUNES and Asset UPnP all fully registerd.
                              in 2017 i downloaded TuneFusion but i'm not able to use it anymore it always says: Bets is expired -so my question - where can i download the actual version
                              Frank
