dmc over 3 million downloads 16 months
  • Razgo
    • 2532
    http://download.com.com/sort/3150-2140-0-1-4.html?
    WOW!!!
    and Easy CD-DA Extractor 6.2 almost 4 miliion downloads in a little over one month?
  • MasterOfPuppets
    • Nov 2002
    • 139
    Impossible..they've hardly have 5,000 in the past week. Must be an error.
    Toute votre base sont appartiennent à nous!!!
      Re: dmc over 3 million downloads 16 months
      It is since the program first appeared on download.com
      • Razgo
        • 2532
        i was thinking that too, but it says date added: 10/16/2003
        • OldCoder
          • Sep 2003
          • 90
          Eventually, those numbers will turn around. Spoon's work is better, although it may not always seem too quick since he keeps more "irons in the fire" than any other coder I've encountered.
          His high level of support takes times too, but the results - really nice, solid code.
          If he keeps this up, one day Illustrate will be purchased by someone big (like Syntrillium was by Adobe), and he'll retire to wherever he wants...
          • Razgo
            • 2532
            user rating 89%
            697 votes
            it is "the" only ripper with this amount of votes with the highest user rating.
            it's not far off being a total number one in every respect of the word.
            • Paddy
              • Jan 2003
              • 71
              It is definately getting there, if you look at the stats for last week:
              dBpowerAmp Music Converter 9.0 - 48,682
              Easy CD-DA Extractor 6.2 - 3,835
              It won't be long until DMC catches up :D
              • Razgo
                • 2532
                wow, i never lõoked at the stats for the last wêek. it sure won't be long.
                not sure what happened to dap though. it will nêd some new promotions to give it a bõost toõ.
                  Funnily enough the only reason I started dMC (on a suggestion from Jackie @ Audiograbber) was to pull people in to dAP...
                  • Razgo
                    • 2532
                    i guess the vast majority are focused on ripping? i saw another section at download.com called "music management". i haven't looked into it yet but perhaps that's where dap needs to evolve to?
                    • Razgo
                      • 2532
                      well after having a better look at that category "music management" it would seem that's what dap really is. as opposed to a music player? must be some fine boundaries between the two?
                      • OldCoder
                        • Sep 2003
                        • 90
                        Those boundaries will be even thinner after Spoon gets his "Master plan" underway......
                        • donny
                          • Oct 2002
                          • 761
                          Well I can sure say that dMC did drag me to dAP - and I am so glad beacuse of it:D
                          • Razgo
                            • 2532
                            and i think it won't be long before the codec compression playing field starts to settle down and once more the attention will be turned to actual music players/management systems.
                            and guess who will be there waiting dap of course!. when i fire up MMC it really is advanced even though Spoon has much more planning/features to add to it.
