Dual boot Win 7 and 10 - same installation?q
  • nathanarizona
    • Aug 2016
    I currently have your product installed on Windows 7; I dual boot on the same machine to Windows 10. Is it possible to point/start from the same installation folder in 10? Have not tried it for fear of screwing up registration.
  • nathanarizona
    • Aug 2016
    Re: Dual boot Win 7 and 10 - same installation?q
    Any chance this will be answered? Getting tired of booting back to Win7 for just one program...
      • 1932
      Which version do you have? Maybe your version is compatible with Windows 10. Registration should be no problem at all, as long as you have the email with the order confirmation.
        You would install it on Windows 7, then also install it on Windows 10 to the same location on the HDD.
        • ForSerious
          • Aug 2017
          • 120
          I'm really curious how your dual boot setup is holding up. I had this on mine until Windows 7 ate 10. I used 7 more anyway and don't miss 10. I just want to know if you've had something similar happen.
