upgrade
  • fla-ts
    • Oct 2014
    • 61
    Re: upgrade
    Track numbers are no problem, that is okay. I'm talking about total number of tracks
      • 1932
      Re: upgrade
      Ok, I got it.
      And why is the "total number of tracks" a problem for you?
      • fla-ts
        • Oct 2014
        • 61
        Re: upgrade
        It's not so much of a problem, it's just that i like clean tags that only contains "Album/Artist/Genre/Title/Track/Year" after ripping.
        So don't worry bout it
        • fla-ts
          • Oct 2014
          • 61
          Re: upgrade
          I must having a bad day today, wanted to change the genre list at the single version and also at the bath ripping version. Can't find the genre.txt
          What do you mean by %appdata%. Can't find genres.txt anyhere at my computer
            Re: upgrade
            Open Windows file explorer (not internet explorer)
            and into the address bar type
            %appdata%
            • fla-ts
              • Oct 2014
              • 61
              #21
              Re: upgrade
              Done, tooks a long while and find thousends of places with "appdata", is there a shorter way to find the specific genre file
                Re: upgrade
                type %appdata%\dBpoweramp\ in the address bar
                • fla-ts
                  • Oct 2014
                  • 61
                  #23
                  Re: upgrade
                  Super, that is the fastest way to find it, thanks mville, I'll beter save this one:Click image for larger version
