dual screen display issue
  • dou
    • Sep 2026
    I have been using DMC for a long time, and after an update, I found that when I right-click on a file on the desktop and select convert to, the window will default to display in the center of two screens. Normally, it should be displayed in the center of the main screen or on other secondary screens in memory. If i do the same way in the folder window, the convert window will display correctly. I recently purchased the image and video converter are also have this issue.
    I searched for history posts and found that it needs to be set from the registry? I think this should be a default parameter, just display in the center of one screen. And the options mentioned in that post are no longer available in the latest version.
    Is there any way to solve this problem?
    How are your screens layed out?
    • dou
      • Sep 2026
      My two screens are plugged into the two ports of the graphics card, and the system recognizes them as separate screens and provides separate taskbars for each screen. These two screens were not merged into the same large screen by the software ("surround" on the driver).
        We cannot reproduce sorry, it always opens the converter on the main screen.
        • dou
          • Sep 2026
          Can you please confirm again? I have looked through the history versions and found the issue starting from DMC R16.5. In 16.4, the window can appear correctly in the center of the main screen, but it will not follow the position of the folder window. In 16.5 and later, the window opens in the middle of two screens, but when open under a folder window, it follows the position of the window.
          It looks like previous versions were automatically managed by Windows, but later it became a designated position.I saw this change on your post.
          Can you find the reason for this difference? If possible, I would like to have a setting restored to version 16.4. I often edit audio files on my desktop, and this setting is very important. And I have found that there is currently no way to force the position of the window by other plugins, and most likely it can only be set in the software's programming.If appropriate, please add my request to the wish list, thank you.
            Which version are you using?
            • dou
              • Sep 2026
              I am using 2026-09-13 and I hope it can have the same display mode as R16.4.
