Cannot connect dbpower.com message when click "Check For Update" icon
  • chng
    • Jun 2021
    Greetings, appreciate your assistance. I am using Window11pro version 25H2 OS build 262.82.46. When click the check for update icon this message appears Cannot Connect to dBpower,com,
    Thank you
    • 46228
    Which version of dBpoweramp do you have?
    • chng
      • Jun 2021
      Greetings, sorry for the late reply, it is Release17.4 (64bits) Thanks
        • 46228
        Yes the older version will not access our servers, it is 10 years old and the version of SSL for HTTPs has been retired.
        There are no further updates for R17, you can ignore the message.
        • chng
          • Jun 2021
          Okay Thanks for the information
