Issues in Win 11 not seen in Win 10
  • LevisGuy569
    I transferred my subscription from a win 10 pc to a newer win 11 pc. several things are different and are quite annoying and it makes the product seem cheaper and of course, less user friendly
    1. when i right click on a folder containing audio files, there is no dbpoweramp option to edit the metadata. (as in i download a digital file from bandcamp in a lossless format). sure i can open the folder and select all, but it is a major pain, it was better and easier the previous way.
    2. when ripping a CD, the track rip status does not update as a %, as it rips the track, it stays at zero % (thought the status bar does move along). the overall status icon in the top center of the program does update. it makes the product seem cheaper when for over a decade, it had been performing differently.
    i have added images to outline point #1. i do not have any disc ready to rip so no images of point #2 at this time.
    It is missing the dBpoweramp menu on the right click, try this:
    Uninstall dBpoweramp, full shutdown restart of Windows, then reinstall.
    You should see a dBpoweramp menu with Convert To and Edit ID Tags in there.
