Upgrade Discounts
  • CJT80
    • Aug 2015
    • 21
    Upgrade Discounts
    Good Afternoon, I have not used dBpoweramp for a number of years, and I have recently wanted to start using it again. The version I have is R15.3 Single PC and I am interesting in taking advantage of the upgrade discount. If I was to upgrade to the Reference Personal pack, can I use it on both a PC and a Mac with one purchase?
    Thanks in advance
    CJ
    Yes if you go for the Family pack, which allows multiple simultaneous installs.
    • CJT80
      • Aug 2015
      • 21
      Hi Spoon, ah OK so the family pack allows multiple installs but the reference is just one install? Just wanted to be clear.
        Correct.
        • CJT80
          • Aug 2015
          • 21
          Thanks for confirming
          • CJT80
            • Aug 2015
            • 21
            Spoon can I trial the new dBpoweramp before committing to purchasing the upgrade? I have had an issue with another "free" CD Ripper and want to check if dBpoweramp has the same issues. Thanks in advance.
              Sorry once the trial has expired it is not possible to reactivate it.
              • CJT80
                • Aug 2015
                • 21
                I have not had a trial of the software before, I have an old version of Reference R15.3 which I have not used or downloaded in years, and want to upgrade it, but I wanted to try CD Ripper on two CD's to check they do rip first. Apologies if I have not explained myself fully.
                  Install the latest trial version to test.
                  • CJT80
                    • Aug 2015
                    • 21
                    Thank you I will do
                    • CJT80
                      • Aug 2015
                      • 21
                      Just wanted to feedback that both the CD's that would not rip with the other software ripped fine. I had an initial issue where the AccurateRip caused the CD to eject but after setting it up I had no issues. I will be upgrading my licence to the new version later today
