dmc configuration
  • drummerdave
    • May 2002
    dmc configuration
    under the dmc configuration, i cannot check the id tag option. I have installed the power pack and am registered. Any suggestions?
    For Windows 95/98/ME you get to the tag editing by Right clicking on audio file >> Edit Tag
    which in my opinion is a faster and better way.
    • drummerdave
      • May 2002
      Thanks, But Still not working.
      Thanks for responding. When I right click the file the is no option to edit tag. And like I said, in the dcm configuration options it will allow me to turn on the "convert to on explorer right click" and "popup info tips" but it won't allow me to turn on "explorer id tag property pages". Any other suggestions? Thanks
        Make sure you have the latest Release 8 of dMC, and that when you right click on a file you have the 'Convert To' option.
        • zyygg
          • Jul 2002
          I also have the same problem with the "Explorer ID Tag Properties Pages not showing up. I have the dmc 8d. I didn't have this trouble with dmc4.
            It is no longer an option in Windows 95/98 or ME, right click on a file and select 'Edit Tag'
            • Razgo
              • 2532
              it should look like this when you right click.
