Mozilla Firebird 0.7
  • Razgo
    • 2532
    mozilla firebird 0.7 is out if any one is interested. a nice fast browser :D
    http://www.mozilla.org/products/firebird/download/
  • MasterOfPuppets
    • Nov 2002
    • 139
    i use opera (the greatest part about it is definitely the mouse gestures), also a nice fast browser :D
    also i have lynx on my other computer.
    anyone still using IE?
    Toute votre base sont appartiennent à nous!!!
    • donny
      • Oct 2002
      • 761
      Re: Mozilla Firebird 0.7
      I also use Opera- it is simply great - specialy that mouse gesture thing you mentioned
      I use IE only if some site refuses to open as it should in Opera (which, of course is not opera's fault)
      • Razgo
        • 2532
        i used to swtich a lot between IEx and opera and mozilla. but finally settled on firebird because i only use the browser as a browser. i don't use browsers for email or bookmarking or anything else. so firebird suited me in the end.
          Firebird does also support the gestures mentioned from Opera -- there are all sorts of plugins available (even one to switch user agents so you can use sites that are hardcoded to accept netscape or IE to avoid support calls). Will
          • MODatic
            • 230
            I haven't used IE as my main web browser since the release of Mozilla 0.9.8 way back on February 4, 2002. Mozilla Firebird 0.7 and Mozilla Thunderbird 0.3 are my main internet apps atm. Just in case you weren't aware, there are optimised Firebird builds in circulation which have been specially compiled to be optimised for certain CPUs and features/instructions (SSE & SSE2)
            The optimised 0.7 builds can be found on the linked page below:
            I do notice a little speed difference with -Oxs -G7 -arch:SSE build on my AthlonXP but most of it's probably a placebo effect.
            Good to hear you've switched to Mozilla Firebird, Razgo! Nice not having all sorts of adware, spyware & malware installed all the time?
            Cheers,
            [color=Blue][b]MODatic[/b][/color] :)
            [url=http://www.modatic.net/]modatic.net[/url]
            • Razgo
              • 2532
              Modatic!! your alive!!! i haven't seen you around for a while or even on your forum. well good to see you online again anyhow
                I have downloaded this, but I've been using K-Meleon which is based on the Mozilla code..... or Opera...
                Unregistered
