Command Set configuration into dMC Audio CD Input
  • MrGeo
    • May 2002
    Hello,
    dMC Audio CD Input seems to work find but I'm looking for informations on command set configuration.
    What setting should I use to optimize Reading with my PlexWriter 24/10/40A ?
    Is Error Correction working ?
    Thanks for any informations.
    • 46186
    The first command set should be used by 99.999% of people.
    EC is not used yet, it does not do as you say though - it does not error correct, but rather highlights a flag to say the last read was corrupt (dirt or scratch), some other CD rippers then pick up on this and re-read the same section over-and-over again in the hope it will get lucky. I hope to stick this in for the next release in 4 weeks.
