Can't install Reference R15
  • cristophersagar
    • Jul 2015
    Hi
    I have just reset my PC back to its factory settings and reinstalled all Windows updates. I'm currently running MS Vista with Service Pack 2, 32-bit. I have just purchased Reference R15 & PerfectTUNES as a single user. Whilst PerfectTUNES seems to have installed correctly, when I double click on the Reference R15 executable file (file name: dMC-R15.3-Ref-Registered), it fails to open. There is moment whilst the hard disk is in use as it attempts to begin to open the file, but then everything stops. I have also tried downloading a new executable file in case the original was somehow corrupted, but this doesn't make any difference.
    Cris
    Re: Can't install Reference R15
    See:
