Hi All!
Thanks for the good response last time. Really helpful!
Got a question not quite about db poweramp, but something closely related. Wondering if anyone else has experienced this strange phenomena that I'm about to explain.
Started tagging via Media Monkey, as I find it much easier because you can just select a whole load of songs at once and batch tag them.
I added a bunch of files to MM library, and went ahead and tagged them all.
The file destination is in a folder that syncs directly to One Drive for backup.
I noticed that all the files I had manipulated in MM had been duplicated, so it looks like the original file is in place, but another file has been created with the updated tagging data I inputed via MM.
Pretty weird!
I have the same track in 3 different folders being synced to the cloud at the same time, 1st copy is an archived original, 2nd is a compressed and 3rd is a copy (which I will delete later as I created it before learning about compression). I tagged all 3 of the same tracks from the 3 distinct folders at the same time in MM, so wondering if this is probably not a good method for tagging? As it has seemingly created a data monster!
SPOOKED!
Any ideas on what I should be doing about this please?
Thanks in advance
JTP
Pretty weird!
SPOOKED!
Thanks in advance
JTP
