Where is DVD-Audio ripper ?
  • Tytun
    • Sep 2003
    Where is illustrate DVD-Audio ripper ?
  • Razgo
    • 2532
    Re: Where is DVD-Audio ripper ?
    there is non that i know of. i think spoon has this in mind for future developement.
      DVD audio is encrypted. To get to it you have to decrypt it. There is software online that will decrypt DVD's and put them on your hard drive. There is software to rip the audio from the video. In some cases you can open a decrypted .vob file using Spoon's winamp plugin adapter with the proper winamp plugin and get it to rip the audio. DVD's can have multiple soundtracks so it's not always that easy. You must have a lot of free space on your hard drive either way.
      Unregistered
        Hi
        About a year ago someone was telling me about dvd ripping, the sound has to be ripped seperatly and then converted and then matched up to the ripped picture but the picture ripping was taking about a day, I gave it a miss as seemed to complicated fo me, but all the software was on the net. I seem to remember a film took about 1gig at reduced quality, good luck!
        M
        • steptoe
          • Feb 2004
          Use a program called DVD Audio Ripper, its not free but will do exactly what you want and convert the audio to MP3
          • desert rat
            • 9
            Go to Audiodvdcreator.com or if that's not right, Google it and you will be able to download the program for 14 days. After that buying it costs 39.95. It works very well and you can convert to formats using dbpoweramp. Instructions were obviously written by the Chinese but is simple to use. I get 6 hrs. uncompressed so you could get huge amount of MP3's etc. It plays on most DVD players.
