Codec Updates...
  • rggauld
    • Jan 2014
    Codec Updates...
    I have a question regarding codec updates...
    If newer versions of codecs are released, do I have to uninstall the older codecs before installing the newer ones?
    Or can I simply install the newer codec over the existing older one?
    Re: Codec Updates...
    It is best to uninstall, then install new.
