Registration confirmation
  • Anodyne
    • Dec 2014
    This is all rather new to me. Today I trialled db poweramp and tried ripping some cd's with great success. I have purchased a family pack and have an invoice number. On attempting to run the program I can not detect any significant difference to the trial version. How can I determine whether I have done this correctly?, I don't want to find that at the end of the trial period that the effort that was put into ripping just disappears.
    • 6188
    Re: Registration confirmation
    trial version if same as full version, it just ends at a certain time. But no worries, nothing you rip with dbpa goes away even if trial ended. what happens when you run Dbconfig.exe. It should show you a popup that has the program listed an note that it is "registered". This is the location for auto updating your program as well, so you need to locate this and run it. I create a shortcut from dbconfig.exe so I can easily access it in my start menu.
      • 46186
      Run dBpoweramp Configuration, if it says Registered Reference, then is registered.
      • Anodyne
        • Dec 2014
        Thanks, it is registered
