Release 15.1 - Edit ID tag not working
  • jibi049
    Hello,
    I'm currently using dbPoweramp 15.1 32 bits on a fresh install of Windows 8.1 64 bits. However the Edit ID tag option of the right-click menu is not working. "Convert to" behaves properly.
    I tried to uncheck then check again, uninstall dbPoweramp - reboot - reinstall, but it did nothing.
    Could you help me ?
    Thanks !
    • 46228
    Re: Release 15.1 - Edit ID tag not working
    What happens if you install the 64 bit version, it works?
    • jibi049
      I didn't try and to be honest some codecs I need are not available for this version :-(
