I've used dBpoweramp since version 11 and I'm currently using version 15.1. For the last few months I've had a problem with the 4 Windows Explorer shell extensions crashing. These are the two right-click entries to convert and edit tags and the information pop-up window when the mouse hovers over an audio file. I can sometimes get these running again with ShellExView. What is causing the crashes and how can I fix it? I'm using Windows 7 Home Premium SP1 64-bit.
dBpoweramp Explorer Shell Extensions Crashing
Re: dBpoweramp Explorer Shell Extensions Crashing
I've tried disabling and enabling 1 of the 4 at a time and that doesn't. Usually, I have to disable all 4, then enable the dMC shell module and dBpoweramp shell interaction first, then the 2 handlers (dBThumb and explorer property). If you use ShelExView and sort by company you'll see what I mean.Comment
