What kind of heatpipes and cooler should be used in the HFX Monster case?
  • Using_it_as_pc
    • Mar 2014
    I just got my computer built and it has Borg FX Bridge and Borg FX Extension Heat pipes. It also has Borg FX CPU Deluxe (copper)
    Are these the correct cpu cooler and heat pipes that should be used with this case?
    The case seems warmer to the touch on the right side than left. Is this normal?
    The specs are Core I7 4770 Haswell, 1 solid state drive, 1 dvd player, 1 dual port (non-sli) video card.
    What should the operating temperatures be for this system at idle? low usage? and moderate usage?
    • 46370
    Re: What kind of heatpipes and cooler should be used in the HFX Monster case?
    You would best be asking HFX, their website:
    Because they are a separate company to ours.
