help
  • bpatt
    • Dec 2013
    help
    i have music in my itunes library that cannot be played because it cannot be located. i purchased the music from emusic and put in my itunes library. Can the db power converter fix this?
    • 46229
    Re: help
    No I do not think it would help, files are files, if they cannot be located then they are missing.
      • 6189
      Re: help
      your files probably are somewhere on your computer where you downloaded them....just not in the location that itunes expects to find them. do a harddrive search for the file name of one of the downloads, or look in the directory "downloads" or "documents\music" etc. Also check that your music library location for itunes is correct. If something changes about that, itunes is not good at autommatically finding any new location of the files.
