Sveta Portable Audio Wish
    It would be really nice if the folder window had a refresh feature on it. If you open Sveta, but you continue to encode new cd's you have to close and re-open the app. You also have to disable the auto-unmount feature otherwise your Ipod (in my case) is unmounted in the process.
    Cheers.
    Noted.
