Question about Registration
  • PeterFuller
    • Oct 2013
    I downloaded the Release 1.14 and used it as the trial, it was great so I registered. I did not delete the trial version. I successfully installed the new Registered version. However, when I look at the software I cannot tell if I am running the registered version or the original trial version. How can I tell which version I am using? I see the word "Registered Reference" on the Versions page in the Configuration screen.
    It would be nice if DbPowerAmp used the same "About" format as the other Windows programs. Anyway, am I OK or do I need to uninstall dbpoweramp and reinstall from the registration download please?
    Peter Fuller
    Re: Question about Registration
    The configuration program is the about page for all programs, if it says Registered Reference then all dBpoweramp programs are registered.
    • PeterFuller
      • Oct 2013
      Thank you. That puts my mind at ease
