Lyrics in Dbpoweramp
  • sam153
    • Apr 2013
    Hi Everyone, Does anyone know if dbpoweramp allows you to edit and add lyrics?
    Any help would be appreciated
    Thank You
    Re: Lyrics in Dbpoweramp
    Depends which audio format, unsynchronzed lyrics are simply a text field in the tag, and should be supported.
    • sam153
      • Apr 2013
      Thank you for your response. I have been trying to find a way to add and edit lyrics for a while, every time I think I found a program something else goes wrong. I am thinking about trying this program but I can't afford to pay if my trial has already expired, I think I had it on this computer a year ago but I was never able to test it out completely. How will I know if I can't try it? Has anyone had success editing lyrics using this program and them showing up in WMP?
      Would I have to do a custom lyric tag thing? I know I tried before but I don't think it worked and I don't know if that is my lack of knowledge or that this program is not capable of that kind of action.
      Any advice would be helpful.
      • dbfan
        • Jan 2011
        • 937
        I did not think WMP displayed lyrics
        • sam153
          • Apr 2013
          Actually surprisingly after much research It does and it has worked so far as long as they don't change this version again.
          You have to chooses in WMP itself to show lyrics and if you have lyrics embedded in your music files it will show up.
          In the earlier version of WMP they use to allow you to add lyrics and edit them. When they came out with WMP 12 they took that tool away. I thought I found a program that replaced that. Now for some reason all of my .wma files are showing that there is no tag info in them.. That is what brought me to this program. Anyway that is the problem on this side. If anybody has any idea that would be great.
