Powerpack Supporters
  • Razgo
    • 2532
    made a change in user control panel:
    the usergroup "powerpack supporter" can now be changed in your user control panel. in other words you will see an option to which group you want to be identified in. so if you choose the "powerpack group" it will show the rocket and title.
    just click "usergroups" in your control panel to see it.
    there are no special privileges in the forum, it merely shows you support the powerpack. one day if a liscencing system can be intergrated into the forums then it would be accurate. but for now it's just a way to show your support.
