Gapless and NAS connected to a DAC
  • lampedepoche
    • Jan 2013
    • 19
    Not sure i'm on the good topic. but anyway.
    Someone knows a NAS server who is able to be connected directly via USB-2 cable to a DAC (prefered method) or via DLNA and networks receiver engine connected to a DAC with a true gapless availability. (Like Dark side of the moon CD)
    By exemple Synology DS Audio isn't gapless.
    Thanks to all.
    Re: Gapless and NAS connected to a DAC
    You could use a PC or netbook PC, install dBpoweramp Renaissance and it would play gaplessless from all UPnP nas's
    • lampedepoche
      • Jan 2013
      • 19
      Thanks for your answer Mr. Spoon.
      In fact, i don't whant to use any kind of PC.
      Only a NAS connected directly via usb cable that push files-flac on the DAC and be connected to the HiFi device.
      Or second, a solution a NAS to a networked device like Yamaha NP-S2000 (via DLNA)(This device seems to be not gapless and the DAC seems a bit cheap) that read files from NAS, convert them and push them to a DAC if not allready integrated into the networked reader .
      Just for my knoledge, what is dBpoweramp Renaissance ?
      • dbfan
        • Jan 2011
        • 937
        It is a gapless UPnP player
