CD Writer error
  • aladdinsgenie
    • Jul 2003
    • 15
    CD Writer error
    After burning about 5 CD's on the trial version I got a sing saying that the CD Writer had preformed an illegal operation then the following message. What should I do?
    CDWRITEWORKER caused an invalid page fault in
    module CDWRITERXP.OCX at 018f:01f4f976.
    Registers:
    EAX=00000000 CS=018f EIP=01f4f976 EFLGS=00010246
    EBX=0290fdb0 SS=0197 ESP=02810000 EBP=02810018
    ECX=028100c0 DS=0197 ESI=8199be80 FS=333f
    EDX=bff76855 ES=0197 EDI=028101b4 GS=0000
    Bytes at CS:EIP:
    50 ff 75 fc ff 75 14 ff 75 10 ff 75 0c ff 75 08
    Stack dump:
    00000000 00000000 028101b4 8199be80 0290fdb0 01f8b850 0281003c bff76849 028101b4 0290fdb0 028100e8 028100c0 0290fdb0 bff76855 0290fdb0 028100d0
    • 46229
    Looks like you have come across a bug in the writing component. If you want to risk another CD-R, try and burn again - it is possible that it was a computer glitch that caused it (doing other things whilst burning?)
      • aladdinsgenie
        • Jul 2003
        • 15
        RE: CD Writer
        it won't burn any CD's. i just get the stupid sign. :sad:
        • aladdinsgenie
          • Jul 2003
          • 15
          RE:CD Writer
          I tryed to burn another CD and got this message:
          The application overflowed its stack. This is typically caused by unrestricted recursion or an exception inside an exception handler.
          Module Name: CDWRITERXP.OCX
          Description: CDWriterXP Control
          Version: 2, 0, 0, 1
          Product: CDWriterXP Control
          Manufacturer: NUGROOVZ
            • 46229
            Is there something special about the CD you are burning? is it a Standard Audio CD? or a mp3 CD?
            are there lots of tracks, or files?
            • aladdinsgenie
              • Jul 2003
              • 15
              CD Writer
              I have a hard time understanding about codec's so am having a hard time with getting the music all straight. I have Adeptec software on my computer so there might be a conflict. Thats why i wanted the trial version first. The reason I wanted this one is to convert some songs that the other dbpoweramp converted couldent (or wouldn't) do. I have soms songs that are supposed to be wav's but say they are Mp3's, plus i have a few od ball formats, that this one was converting nicely untill i got to the 6th Cd.
              Is there a way to use the CD Witer to convert then save to a file in the new format? I wish there were a "convert to cda" format on the dbpoweramp music converter. That would solve my problems!!
              If i registered this, are there more features to it? And can I get it on a CD so reinstalling it would be easier?
                • 46229
                There should be no conflict between Adaptec (which Windows Version do you have?)
                It is possible you have found a combination of files that the Writer is having problems with, why I am not sure, but by the time you click 'Burn CD' everything should be already converted for the CD.
                One thing to check is you have enough Hard Disc space, I am assuming you have one drive - c:, check the free space runs to at least 800 MB.
                I would give up on that CD and try a different one, with different files - run 'dBpowerAMP CD Writer' and click 'Delete CD' to clear all the files from it to start fresh.
