GLOSSARY for DUMMIES?????
  • Tom Swaman
    • Oct 2011
    • 258
    Am I alone or would we benefit from having a glossary of the terms and "alphabet soup" used by DBPA and related audiophiles and audio using amateurs? Maybe it is just me, but I have real difficulties reading the various DBPA lierature, explanations, etc. because I am not used to the vocabulary or to the abbreviations. So if I had a glossary by Spoon or equal that might spoon feed dummies like me, I think we could benefit from using DBPA and also better contribute to this forum.
    With appreciation for your consideration,
    Tom
    Re: GLOSSARY for DUMMIES?????
    • Tom Swaman
      • Oct 2011
      • 258
      Spoon,
      Thank you. I have read over your Audio Guide many times. I will try once again.
      Regards,
      Tom
        Originally posted by Tom Swaman
        Spoon,
        Regards,
        Tom
        and google is your friend. You can often google a term and find its meaning. Also, one can always simply post specific questions here and people are typically quick to help define a term.
        • Tom Swaman
          • Oct 2011
          • 258
          Thanks Gary. Your answer is excellent and I do try to do as you state.
          Regards,
          Tom
