Upgrading batch ripper and music converster versions
  • Tom Swaman
    • Oct 2011
    • 258
    If I upgrade my software from version 14.2 to 14.3 for the batch ripper, are there any known problems or effects on my stored music using the FLAC cogec? I ask the same question, please, for upgrading the music converter to the latest software version?
    Are there any known reasons to not upgrade my batch ripper and music converter software to the latest versions?
    Thanks for the help,
    Yom
    Re: Upgrading batch ripper and music converster versions
    You might want to hold off 14.3, as 14.4 (currently in beta) has fixes to FLAC tagging which may or may not affect you.
    • Tom Swaman
      • Oct 2011
      • 258
      Great and very helpful answer for me. I will do as you say, Spoon.
      Much appreciation,
      Tom
