eject disk crashes the system
  • mdziv
    • Mar 2012
    On my HP dv6T with 'BD E DS6E2LH' CD drive, the eject disk command crashes the system (Win 7 Home). How to fix that? How to disable aautomatic 'disk eject' after ripping?
    • 46228
    Re: eject disk crashes the system
    The automatic eject option is under the options button.
    Try R14.3 (in the beta section of this forum), it might correct your issue, please report how it goes.
    • LKstar
      • Mar 2012
      Sigh. I am crashing as well.
      My crash occurs almost immediately after I press the RIP icon.
      The dbpoweramp display window flickers; the ripping initializes but then freezes; the Hard Disk light is solid red, and the CDRom drive light is not on or accessing the CD.
      I have no desktop control and I use Task Manager to shut down the computer which then hangs, and I end up hitting the RESET button.
      Tried different CDs.
      After Ripping is set to nothing so my auto eject is NOT selected
      I've tried reinstalling.
      Even tried the Beta release.
      The symptoms are consistent every time.
      Sigh... this dog just won't hunt.
      PC Info:
      OS: Windows 7 64bit
      RAM: 12GB
      Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz, 3068 Mhz, 4 Core(s), 8 Logical Processor(s)
      Drive: Name: HL-DT-ST DVD-RAM GH22LS30 SCSI
        • 46228
        Try a clear:
        http://forum.dbpoweramp.com/showthre...rom-the-System
        Then reinstall and try ripping a cd without changing any settings.
        • LKstar
          • Mar 2012
          Did what you suggested. I made no changes during setup. I got a little further, this time. dBPoweramp ripped the first song fine...but crashed on the second song. Same symptoms.
          Gonna try an older version of software. At one point dBpoweramp worked fine on my PC. The only hardware change I've made since was I upped the RAM memory.
          • LKstar
            • Mar 2012
            Tried a different CD ROM Drive and it worked!
            I figured it couldn't hurt to try another optical drive before reinstalling for the umpteenth time. Used my portable ROM drive for my laptop and it worked.
            My desktop optical drives works fine in all other scenarios but for dbpoweramp.
            I was wondering could it be that dBpoweramp didn't like that the drive is on a SATA 6Gb/s port instead of a 3GB/s? I had to configured it like this because Intel Controller has problems with certain drives and my LG was one of them. However the port was backwards compatible and I had no issues until now.
              • 46228
              It is possible the interface is crashing the CD drive, which is then inturn freezing CD ripper.
