If I purchase dBpoweramp...
  • Grace
    • Jan 2012
    I was wondering If I purchase dBpoweramp do I get access to updates and or new versions of dBpoweramp for life or will I have to purchase again?
    Forgive me this is probably the wrong place to ask this but I didn't want to post two threads. :o
    I have two drives the first is a cheap (less than $10 :blush LiteOn CD/DVD RW 22 x the other is a Pioneer Blu-ray RW 12 x (I paid about $40). EAC recommends using the LiteOn drive for CD ripping, I haven't had any problems with either drive but would I get better quality rips if I bought a better drive? If so could you please recommend one. I have a spare expansion bay but don't mind if internal or external and price isn't important. :p
    Grace
    Re: If I purchase dBpoweramp...
    Minor version updates are included, such as R14.3 R14.4, there would be an upgrade fee to major updates (ie R15)
    Drives only different in their ability to recover from errors, if AccurateRip is verifying the rip, you cannot get any higher quality then a bit perfect rip.
