14.2 Reference Trial is just the standard product. Do I have to activate Reference?
  • Nypro
    • Dec 2011
    I have just downloaded and installed the 14.2 Reference Trial (dMC-R14.2-Ref-Trial), but it appears to be the standard product after installation (see below for clipboard copy of installed versions).
    I wanted to try the batch ripper, so I also installed that but I can't start it as it says I need the reference product, which I thought I had installed. Have I installed an incorrect version or do I need to enable something?
    Thanks for any help...
    __________________________
    Clipboard versions:
    dBpoweramp Music Converter: Unregistered Trial (21 days remain)
    Release 14.2
    Asset UPnP: UPnP (DLNA) Audio Server
    Batch Ripper: Release 1.5 [Unregistered Requires Reference]
    dBpoweramp CD Writer:
    Audio CD burning simplicity
    Re: 14.2 Reference Trial is just the standard product. Do I have to activate Referenc
    You need to run in an account with administrator access rights for the trial to activate.
    • Nypro
      • Dec 2011
      Great, thanks for the swift reply.
      • A Lex and Er
        • Aug 2012
        HaHaHa, yup same question... Thanks for answering it before I even asked!
        This should be mentioned in FAQ, I think.
        Kinda weird, why is admin. needed? To disable extended features after 21 day trial?? My guess! ???
        Anyhow, thanks again!
