Edit ID-Tag with WAV
  • dummy
    • Dec 2011
    • 25
    Hello,
    I was wondering If you edit/added metadata to an already ripped music WAV folder/file, If it was embedded or not?
    I keep reading It can't be done with WAV unless you re-rip all over again, yet I tried with Edit ID-Tag and It works. Well, at least the new/changed data/art shows in JRiver. Does that mean It is really embedded to the file/folder and It will show in any players I may choose in the future?
    Thanks!
    Re: Edit ID-Tag with WAV
    It is embedded.
    • dummy
      • Dec 2011
      • 25
      Thanks a lot Spoon!
      You cracked the code and now that I know that Edit ID-Tag embedded everything/anything I choose to change, It is exactly what I was looking for, for the longest time.
      You're Da Man allright Sir!
