Ripnas S1000 assign static ip address
  • mossie264
    • Nov 2011
    I am new to the forum and to RipNas.
    Can anyone explain to me how to get the Ripnas on a static IP address using Mac OS.
    Question must have come by a thousand times, but I just cannot find the answer.
    Your help is very much appreciated.
    Best regards,
    eric
    Re: Ripnas S1000 assign static ip address
    Normally you can set your router to give out a certain address for a given network MAC
    • mossie264
      • Nov 2011
      Thanks for your reply.
      So in the router I just assign the IP address and the RipNas will use the correct subnet and gateway and so on?
      BR
      Eric
        Yes
