Review metadata
  • agodoc
    • Oct 2011
    Review metadata
    dBpoweramp reference 14.2
    Review Metadata button don't work properly, but message error appears:
    Metadata was not retrieved from the internet (most likely from local HDD cache)
    Press the metadata button to refetch from the internet
    Re: Review metadata
    You have perfectmeta enabled on the meta drop menu?
    Try pressing the metadata button then click the review button.
    • agodoc
      • Oct 2011
      Re: Review metadata
      Perfectmeta is enabled.
      I pressed metadata button then click the review button but the same message error appairs.
        Re: Review metadata
        For all discs or just one?
        • agodoc
          • Oct 2011
          Re: Review metadata
          For all discs!
            Re: Review metadata
            Do you get any metadata? shown on the main screen?
            • agodoc
              • Oct 2011
              Re: Review metadata
              Yes all metadata are shown in the main screen, but review metadata don't works
                Re: Review metadata
                Run this:
                Then reinstall the registered version, make sure it says R14.2 Reference registered after installation, then try CD Ripper without changing any options.
