pink noise burst
  • M.Kapitein
    • Aug 2011
    pink noise burst
    With BPoweramp i hear between converted files a pink noise burst approx 1 second receiver Onkyo tx-nr 808 with Wmplayer i hear nothing.
    I convert cda files to wav 96 Khz and 24 bit PLEASE help me?
    Re: pink noise burst
    The onkyo is not reading the wave files correctly, ie it is playing the non-audio ID Tag section. You can disable wave tagging, use the DSP effect 'ID Tag Processing' set to remove all tags.
    • M.Kapitein
      • Aug 2011
      Many thanks for your reply, there's only a very small thick to hear between the files,:smile2: i can life with it
        If using UPnP and Asset, set to transcode as Wave (even though is wave) and the tags are removed when streaming.
