Read Speeds when Batch Ripping
  • qualitydiscs
    I just had a tower built, primarily to digitize large CD collections - quad core, 6 LG drives. It is definitely better than running one CD at a time through a laptop. However, I had higher expectations than the results I am getting (30-40 rips per hour).
    With all six drives running, I rarely get more than 25x on any single drive and I only get that speed on one or two drives at a time - the others typically run between 5x and 15x (usually two drives at 9x-14x and the other two at 5x-9x). If I cycle down to one or two drives ripping at a time, the read speeds jump to 30x-40x.
    Is this an issue with the system. If so, any suggestions? Otherwise, is this a limitation in the software?
    Please help.
    Re: Read Speeds when Batch Ripping
    Answered on your other thread.
