Question re: Edit-ID Tag
  • audiodoc
    • Nov 2009
    The metadata editor (Edit-ID Tag) is great. Just one question...in Media Center the metadata shows a tag labelled "Date Created", yet when I check the metadata as shown by Edit-ID Tag, I don't find a corresponding label.
    Since I ripped the file over a year ago before I ever installed M/C, the only way it could have known when the file was created was if there was tag in the WAV metadata, yet Edit-ID Tag doesn't show it.
    QUESTION: is Edit-ID Tag seeing all the tags imbedded in the native WAV file? And if not, why not?
    Re: Question re: Edit-ID Tag
    Wave LIST tagging has fixed pigeon holes, there are a set number of these, if an application create their own tag value other applications would not know about as it .
