Help with Composer Pro
  • Aging Dead Head
    • Jun 2011
    • 13
    I finally got it all together and Am having problems getting the robot to work,
    Here's the set up
    Composer Pro with the recommended software from Primera (Primo DVD 2.1)
    dbpoweramp 14.1
    Batch Ripper 1.3
    Primera Composer install downloaded and installed
    I have tested the Composer Pro using the software from Primera (DVD2.1)
    and it works perfectly, Picks and places cd's in both drives and hoppers.
    However when I swing over to batch ripper the robot doesn't work
    correctly and comes up only using 1 drive and giving any error for the 2nd.
    I have played with the configuration but can't get it right. I can't find anything to due with instructing me on how to set the CLI sections. When I run the test function I get "Batch error" . So how do I set the configuration to get this thing working. In one test run I actually did manage to rip one CD and download the metadata. I have also manually played DVD's in both drives and they come up on my computer, In the top space for loader configuration There are three choices
    Auto-eject manual load
    Primera Composer
    Primera Composer Max
    There is no Composer Pro
    So which one do I use?
    I am sure that I have the physical
    connections correct. It's all gonna be in the software set up.
    Can someone give me the exact settings to use?
    Thanx in advance
    • 46186
    Re: Help with Composer Pro
    Which connections are on the composer pro to the PC? scsi and?
    • Aging Dead Head
      • Jun 2011
      • 13
      Firewire and Serial (9pin)
      When I run the Primera software (DVD 2.1)in test mode the unit does all functions properly and in correct sequence
      Thanx
        • 46186
        Try any of the ones you mention, click test load to see if it works. If not try different baud rate settings for the serial settings (in Batch ripper configuration).
        • Aging Dead Head
          • Jun 2011
          • 13
          SUCCESS
          I finally got it working
          The problem was that the Composer Install set both drives up to be
          Drivebank 1 in the configurator.
          I went in an edited one set to be all Drivebank 2
          and BAM it's alive (perhaps a little more info on this on the
          in the Configuration overview would be good)
          Now it works and rips
          I have noticed a problem with the robot having an issue sometimes not
          picking up discs from one of the drives. I have made sure the machine
          is dead level and will now go thru the whole Primera Robot Calibration
          Set-Up. This was done before shipping to me but I guess it got
          a little screwed up in transit. Not a lot but I guess enough to sometimes
          screw up disc picking.
          But it's now a matter of fine tuning.
          I'm gonna love this thing
          But I'm sure I will have more questions
          Thanx
