Question about installation when upgrading to R14
  • TempestGarden
    • Jul 2007
    • 23
    I currently have R13 and I have been meaning to upgrade to R14 for some time now. Since there are some major changes with R14, should I uninstall R13 first before upgrading to R14 or is it okay to just install R14 right over the top of R13?
    Re: Question about installation when upgrading to R14
    You are best to uninstall R13, then install R14, your settings in R13 are preserved.
    • TempestGarden
      • Jul 2007
      • 23
      Okie doke. Thanks for the reply.
