I got 2 issues I'm trying to figure out any ideas
  • duker
    • Jan 2011
    1 I'm using an ASRock X58 extreme 6 mobo with 6 SATAII 6 SATAIII connections using 2 of the SATA III connection with ODD and all 6 of the SATAII with ODD as long as I only rip on SATAII's everything's fine but as soon as I start to rip with SATAIII connected ODD the program CRASHES. and I use all the same drives with SLYSOFT to rip dvd's no problem and all drives playback with out a hitch. anybody got any ideas on hoe to get dbpoweramp to play nice with a SATAIII connection? *blooper*2 the program with out rim or reason I can figure out just goes idle. I click around and most times if goes back to ripping occasionally I have exit the program and start over whats up with that? other than that this is a FANTASTIC piece of software. any suggestions will be greatly appreciated, Thanks
  • dbfan
    • Jan 2011
    • 937
    Re: I got 2 issues I'm trying to figure out any ideas
    Sorry what is ODD?
    • duker
      • Jan 2011
      optical drive ie dvd/cd drive
        • 46229
        It is dBpoweramp which is crashing, or Windows?
        • duker
          • Jan 2011
          just dbpoweramp but its more of seized up stop working more than a crash
            • 46229
            First I would uninstall Slysoft as a test as it acts as a go between (between dBpoweramp and the CD drive).
