No tags when encoding to ogg
  • baleu
    • Mar 2011
    I've been looking for a new ripping program and thought I found the perfect one. But there is just a thing that is not working:
    I usually encode my music to ogg-files. The ripping process is absolutely perfect - fast and accurate. But there are no tags! Neither in foobar nor when I look at the files by "Edit song information" from the explorer.
    It works just fine when encoding to Flac or MP3. What am I doing wrong?
  • pfeerick
    • May 2008
    • 15
    Re: No tags when encoding to ogg
    Not sure if this is related, but when I installed the Ogg Vorbis codec to check this out, I don't see any tags in the info tips or in the 'edit ID-Tag' dialog, after converting a tagged MP3 to OGG. And when I add tags using foobar2000, I still don't see any tags. When I tried using the 'Edit ID-Tag' properties panel, I was rewared with an 'Unable to write ID Tags for x' error.
    -Pete
    [COLOR="Gray"]dBPoweramp R14.1 25-MAR-2011 beta on Windows 7 SP1[/COLOR]
      You need to also install the Ogg decoder (as well as encoder if using autov).
      • baleu
        • Mar 2011
        Thank you! Installing the standard ogg decoder/encoder did it.
        Now everything is perfect, it's a really good software
