AAC, Vorbis and CELT. Public listening test - OPEN
  • IgorC
    • Mar 2011
    Greetings!!!
    There has been significant advancement since the last 64kbps test. The Nero HE-AAC and Aoyumi Vorbis encoders improved, Apple added HE-AAC capability, and we have a new low delay codec with high quality: CELT.
    The following codecs are presented in this test:
    Nero 1.5.4 HE-AAC
    Apple QuickTime 7.6.9 HE-AAC
    Ogg Vorbis AoTuV 6.02 Beta
    CELT 0.11.2
    Public Multiformat Listening Test @ ~64 kbps [March 2011]
    Well, have fun! :rolleyes:
    If you don't want download separate packages there is all-in-one package http://listening-tests.hydrogenaudio...nd_samples.zip
    Note: Important workaround was made. It is not uncommon to see that some soundcards have isues with not 48 kHz sample rates. Aslo until moment CELT is optimized for 48 kHz while other codecs are well tested at 44.1 kHz. To avoid these limitations all decoded files (Vorbis and Nero, Apple HE-AAC) were resampled with very highly transparent resampler SOX VHQ while CELT files were directly encoded from the resampled source. The resampling hadn't impact on final results.
    Even the single result is helpful.
  • IgorC
    • Mar 2011
    Re: AAC, Vorbis and CELT. Public listening test - OPEN
    The test is extended until 10th of April.
    We need more results for samples 11 and 14-30 (14,15....29,30) and results for other samples are welcome as well.
    • IgorC
      • Mar 2011
      The test is finished.
      The results will be soon.
