Overread Lead-In and Lead-Out box - check or leave unchecked
  • craig12345
    • Mar 2011
    Hi all.
    My 2nd and I hope last question. I have dbpoweramp now set up.
    Accuraterip has calibrated my sample offset at +102 and is set.
    I want to get a Plextor drive next, but am learning with my current CD Drive.
    I have Manufacturer: MATSHITA
    CD Drive: DVD-RAM UJ-850S
    Firmware: 1.20
    Serial: 70219UKMEMB88043067
    Maximum Speed: 4234 KB/sec (x24)
    Current Speed: 4234 KB/sec (x24)
    Spin-down After: 32 seconds
    Buffer Size: 2 MB
    Accurate Stream: Yes
    C2 Error Pointers: Yes
    Reads ISRC: Yes
    Reads UPC: Yes
    •Overread Lead-In and Lead-Out: Unchecked in most cases.
    Check "Overread Lead-In and Lead-Out" only if the test result says that your drive can overread from both the Lead-In and Lead-Out, or if it says Lead-Out and your offset correction is positive ,or if it says Lead-In and your offset correction is negative. Otherwise disable (uncheck) it.
    How do i run a test or know if i need to check or leave this box (Lead-in / Lead -out) unchecked?
    Regards
    Craig
    • 46186
    Re: Overread Lead-In and Lead-Out box - check or leave unchecked
    Leave unchecked.
