Aiff And Id3
  • jamworks
    • Feb 2011
    Aiff And Id3
    www.dbpoweramp.com says: "AIFF supports ID tagging with album art compatibility, an internal id3v2 tag (compatible with iTunes)"
    However, http://www.id3.org/FAQ says:
    "Q: Are ID3 tags only available in MP3 audio format?
    "Yes. ID3 tags were designed with the MP3 file format in mind."
    Can someone please explain why id3.org doesn't acknowledge AIFF supporting ID3?
    Re: Aiff And Id3
    Apple write ID3v2 tags to AIFF files, to me that says it is supported.
    • jamworks
      • Feb 2011
      Re: Aiff And Id3
      In that case, my concern is whether all players and DAW's can play AIFF files with ID3 tags.
        Re: Aiff And Id3
        You would have to test, it would seem odd if they could not as they could not play iTunes created files.
