Noise
  • javierrodriguez
    • Jan 2011
    Noise
    Whe ripping in multiformat, I found that there is a noise in WAV and MP3.
    Could it be because of some setting of DSP? Could it be the bit from 16 to 32 floating point?
    Tahnks for help
    JAvier
    Re: Noise
    Yes easily, remove all DSP effects and try again, then add one at the time until you find the problem one. With DSP effects it is easy to amplify the volume too much so there is noise so they need to be used carefully.
    • jeffgeorge
      • Feb 2011
      Re: Noise
      i have awful:cry: hiss between songs are how do i get rid of dsp i have already ripped 600 cds.:
        Re: Noise
        You should not have a hiss from ripping CDs, it suggests there is an issue with your player, what is the player and which format did you rip to?
