missing or misused msvcr90.dll
  • esvb
    • Apr 2010
    Hello,
    I really like dbpoweramp... but, I am getting an error message. At first, after installing, when I put in a new cd it would give me an error message about not being able to find msvrc90.dll.
    I then searched, and it is located several placed on my hard drive. I reinstalled, got the same message.
    I then ran Dependency Walker on cbgrab.exe and got the following error message:
    IESHIMS.DLL Error opening file. The system cannot find the file specified (2).
    I then copied msvcr90.dll into the Program Files\Illustrate\dBpoweramp folder, and then started getting a message about the program using the dll incorrectly. I would like to buy the program, but a little concerned about these error messages.
    eric vb
    Re: missing or misused msvcr90.dll
    >IESHIMS.DLL
    This is always missing from any system, it is not needed.
    You have installed all the codecs? one is requiring that dll, if you uninstall all the non-standard ones you can find which it is.
