Convert mp3 to m4b
  • mango
    • Feb 2010
    Convert mp3 to m4b
    I have been looking at your product line as a potential solution for the following problem -
    I need to convert several thousand mp3 audiobooks at once to m4b format on an ongoing basis. I would like to do this conversion from within a php script via the command line. I have downloaded the trial version of dbpoweramp, along with applicable codecs and would like to test its effectiveness from the command line prior to purchasing the requisite licences.
    I tried running the following command as a test, I get the error
    Error [outfile] not specified on command line.
    "c:\program files\illustrate\dBpoweramp\coreconverter.exe" -infile="MyInFile.mp3" -outfile="MyOutFile.m4b" -convert_to="m4b (Audio Book)" -cli_encoder="C:\Program Files\Illustrate\dBpoweramp\encoder\m4b (Audio Book)\neroAacEnc.exe" -errorfile="out.txt" -tag="title=Book Title" -tag="artist=FirstName LastName".
    Can anyone please help? Thanks.
    Re: Convert mp3 to m4b
    Are there no paths for MyInFile.mp3? and the MyOutFile.m4b?
    • mango
      • Feb 2010
      Yes there are paths. But currently, for test purposes, I can store both input and output files in the same folders. The program is launched from inside the input file folder.
        Try:
        CoreConverter.exe -infile="c:\AFile.wav" -outfile="c:\Outfile.mp3" -convert_to="mp3 (Lame)" -V 6
        Then when it works, add in your CLI elements one at a time until you find which is causing the problems.
        • mango
          • Feb 2010
          Am a bit confused. I want to convert from mp3 to m4b, not wav to mp3. I do not have any wav files.
            It is a test, as when you can get that working you can try adding your command line one part at a time until you find what is wrong.
