Firmware Update Problems
  • LdB
    • Oct 2009
    Hi all
    I have RipNAS - WHS on Windows Vista - Transporter arrangement which is doing most of what I want. Problem is though that each time I switch my Transporter connection from "My PC" or "Squeezenet" to "RipNAS" to access my music Transporter automatically Updates Firmware to version 7.4.0 r7790 and next time I connect it (should that be down-dates?) back to version 7.3. r3993. and so on.
    very annoying.
    Any suggestions wht the issue may be would be appreciated.
    • 46229
    Re: Firmware Update Problems
    You could try installing the latest version of Squeezecenter on the WHS box.
    • moley6knipe
      • May 2008
      • 97
      It's because connecting to Squeezebox online services (whatever they're called this week) requires SqueezeBox Server ver 7.4.
      If you don't use any of the new colour screen Squeezebox devices then I'd stick with 7.3.4 until 7.4 works properly! http://downloads.slimdevices.com/SqueezeCenter_v7.3.4/
      • LdB
        • Oct 2009
        Problem is that Transporter seems to do the upgrading and downgrading automatically.How can I ensure that all systems stick to the one version, be it 7.4 or 7.3?
        Incidentally, my clock on Transporter also seems to revert to US tme on eac occasion even though my pc and Ripnas are configured t London time. Is this part of the same problem?
        • LdB
          • Oct 2009
          Update. Followed Spoon's suggestion and installed v7.4, though directly on ripnas via remote desktop, which - fingers crossed- seemed to have resolved both issues.
          Thanks for these helpful hints
